transmission cooler line size 1/4 big enough
I have some 1/4 line with 6an fitting crimped on already. Would a 1/4 inch line be big enough size? The fitting in case is 1/4 to 6an fitting.I figured as long as my hose is bigger or same size as the 1/4 case fitting then the line wouldn't be restricted.trans 4l80e with a supercooler. Thanks
