4l80e shifters for Fbodies
Old 01-20-2014, 05:49 PM
fly boy_1's Avatar
Default 4l80e shifters for Fbodies
What kinds of shifters are available for a 4l80e that fit in a 4th gen? My car is currently M6 so I figure an aftermarket shifter might be better vs finding a stock set up, what options do I have?
Old 01-21-2014, 04:36 PM
willizm's Avatar
I've looked into and couldn't find an option that seemed to work well for the 80e. I just use the stock shifter and had to adjust the bracket so the shifter was lined up right.
Old 01-21-2014, 05:28 PM
soundengineer's Avatar
then you didnt look hard enough...
TCI Outlaw shifter.
I actually mounted mine on a pedestal so it would sit exactly where I wanted it to...
but you can mount it in the stock location if you wanted to.
Old 01-21-2014, 05:33 PM
willizm's Avatar
Works fine even for an OD trans?
Old 01-21-2014, 05:35 PM
yes... its desigend for any 4 speed transmission...forward or reverse valve body
they also make gates for it for other transmissions as well...
its a universal shifter with interchangeable gates.
also works with the TCI 6x that I drive(which is a modified 4l80)
Old 01-21-2014, 05:40 PM
From the TCI Website
Originally Posted by TCI Website
The TCI® Outlaw™ Shifter not only ensures that you find the right gear when you need it but delivers great looks as well. Constructed of billet aluminum with a pistol grip shifter and black-anodized cover with an optional quick release setup, the Outlaw™ Shifter is durable enough to handle both street and race-duty applications.
-Features a Park/Neutral safety switch along with provisions for a reverse light system
Designed for GM Powerglide & most popular GM, Ford & Chrysler 3- & 4-speed transmissions
-Includes 5' of heavy-duty shift cable & all hardware
-3-Speed reverse pattern available
you can also get it with 2 buttons on the front of the handle, and they make a side plate you can swap out to get a side/thumb button if you want it
Old 02-15-2014, 10:09 AM
BIGDRAGON's Avatar
Any other shifters available for the 4l80e using the stock console?
Old 02-15-2014, 12:27 PM
Cole Train's Avatar
nope, just the stock shifter with adjustments...
Old 02-15-2014, 01:13 PM
Burken01's Avatar
TCI Outlaw shifter.
That looks killer, is there a major benefit to running aftermarket vs stock in your opinion since you've tried both?
Old 02-16-2014, 07:14 AM
White.Lightning's Avatar
You can make ANY shifter work that is designed for a 4 speed trans. Just about any shifter will require some sort of modification to make it work.
I've seen some guys use M6 upper consoles to make things easier....
Others have hacked their A4 upper console and put in a more 'race' oriented shifter....
Some have even gone console-less.....
Others keep it simple and run stock....
I plan to do whatever it takes to adapt a B&M Pro Ratchet shifter into the A4 upper console like this....
Old 02-25-2014, 07:57 PM
fbodyman50's Avatar
I want to do the one in the last picture you posted!!!
Old 02-26-2014, 01:34 AM
Cole Train's Avatar
i would do the last one in the pics in a heartbeat that looks awesome. For now though i'm just gonna run the stocker as it works excellent for me
Old 02-26-2014, 07:44 AM
fbodyman50's Avatar
I have the same center console in my third gen though.. so making it different from other is a must for me! I love that shifter!!!
Old 02-26-2014, 08:17 AM
Guitar's Avatar
This is the best looking one I've seen and what I want to do whenever I switch over:
Originally Posted by Kingc8r
Ill be using a B&M Stealth Pro shifter with a M6 center console
Old 02-26-2014, 03:27 PM
5.0 LsX's Avatar
im running the sidewinder, although I don't know how it fits into a fbody...
Attached Thumbnails 4l80e shifters for Fbodies-1383316803890.jpg   4l80e shifters for Fbodies-img_20131229_144956.jpg
Old 02-26-2014, 08:10 PM
JustAFooL's Avatar
I just got done building another mount. This one fits the B&M Pro Stick in the factory console. I already have one that fits the Hurst Quarter Stick into the factory console. Hurst quit producing the 4speed shifter so I had to go with another. Hasn't made it to classified section yet, but will in a day or two. This will work with the 60e if you'll drill the cable out and put it on the factory shifter arm. PM me if interested in one.. BTW, they make an adapter for the 80e too.
In neutral position:
In park position:
In 1st gear:
Old 02-27-2014, 09:57 AM
Billy1987's Avatar
How much for the pro stick mount for factory console ?
Old 02-27-2014, 11:19 AM
JustAFooL's Avatar
They are 65$ shipped and PayPal'ed, Same as quarter stick mount.
Old 02-27-2014, 12:03 PM
RedRocketZ28's Avatar
This is probably a dumb question, but since the TCI Powerglide shifter is the cheapest, I can buy that and then just buy the 4-speed gate correct?
Anyone who has the answer to my (probably ignorant) question, please feel free to chime in!
Old 02-27-2014, 05:28 PM
JustAFooL's Avatar
Not really familiar with that shifter. MOST shifters, yes; you just change out the shifter gate and it adjusts how many gears the shifter will actuate. If the shifter is named Powerglide, I would dig a little deeper.
Quick Reply: 4l80e shifters for Fbodies
