counterbore slip yoke 4l80e?
I went with a mark Williams chromoly th400 yoke $200 on their website
Search th400 yokes and make sure it's counter bored, it will specify in the description
Counter bored yokes are real common, won't be too hard to find
If you get ahold of jakes performance, he sells them
On the old 400's they had the raised part , don't know if it had an o-ring or not, they were for a 2 pc.drive shaft with a bolt on yoke. I have ground the high part down to shaft size and use a standard car yoke.
