Jakes 80e
Jakes 80e
Gotta drop the pan and replace the internal harness so I am gonna obviously need new fluid. Been reading about JD hygraurd vs regular ATF, and was wondering if something like this is an acceptable alternative to JD?
http://www.tractorsupply.com/webapp/...http:ClickInfo
Thanks
Thanks
Regular Dexron type fluid is what I typically recommend. There is no need for fancy fluid for most combos. I recommend the Hygard type fluid for turbo combos that will be spooling on the brake for more than 2-3 seconds.
