Trans temp gauge location, routing ideas, connection help please
Hey guys, I just installed my 3600 converter, and I have a trans temp gauge on the way also, but I need some opinions on where to mount it so it's visible to me, yet not intrusive, like on the A pillar.
Also, how/where should I route the sending unit, and to where on the trans to get the most accurate reading?
Is there an easily accessible grommet somewhere towards the front?
It's an Autometer ultra lite, if that matters.
Thanks.
Thanks.
i ran mine my sending unit off the port right near the shift linkage and ran the wiring up through where the shifter comes up at. I have my gauge mounted in a custom metal holder that eliminates the cubby by the ashtray. it also has my cutout switch mounted there also.
Cool. thanks.
Where did you mount the sender on the trans?
I'd hate to have to remove the pan again, and have to drill and tap it. I just changed the fluid and filter when I did the converter.
not to hijack, but if anyone is considering buying the trans temp gauge and installing, an option u may want to consider is scangauge, i installed one last year, and it monitors trans temp, as well as amillion other things. was like 140 bucks, and is accurate more than stock tach and has a lot of functions.
As far as mounting the gauge...Camaro would either be A-Pillar or a custom install in the center console, for the most part, 6LE has some nice products for that. If you have a Firebird, A pillar, center console, or you can mount it in one of the dash vents. Again 6LE has good stuff for that.
Edit: I had some time...https://ls1tech.com/forums/9089592-post8.html
When I got my converter I was talking to a friend of mine who already had one and he steered me away from the plug. I was planning on using that with a trans temp gauge. After we persuaded me away from it I bought an Interceptor ($235 for 75+ gauges in 1 including trans temp) and it just plugs into the OBDII port.
I run the aeroforce scan gauge, but if I were were to just have a trans temp gauge, Id weld a bung into the side of the pan and put it there.
Op I have a single pod for the A pillar and it doesnt get in the way. For a while I had a vent mounted gauge but didnt like looking down at it.
