th400 swap question
th400 swap question
im getting parts lined out and am just about ready. this is what i got so far. fti lvl3 th400, fti 4000 stall w/ls pilot, tci flywheel, arp bolts. its a forward pattern valve body so gonna use stock shifter. is there anything that i need to still get? will i use the spacer that came with the flywheel? just curious what had to be done to reuse the driveshaft with a 10 bolt?
I didn't see it listed in your mods or in your list but you would also need a trans cooler, lines, cross member and a dip stick... if you don't already have them. I'm not sure about the driveshaft. I'm wanting to say that my factory six speed driveshaft was shorter than the PST driveshaft that I had made. I do not know if the auto diveshaft will work.
LS1Tech Sponsor
The converter we built has the long pilot on it so the crank pilot spacer is not needed!!
Greg
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
LS1Tech Premium Sponsor
These guys are the only company I buy torque converters from! They are the best in the business and they have outstanding customer service.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
