vibration in neutral while coasting
Old 03-16-2014, 01:13 AM
boola1341's Avatar
Default vibration in neutral while coasting
My car has a vibration in neutral while coasting above 40 mph. Once I put back in gear it stops. Also I can be doing about 60 and let off the gas and I get a quick grind noise. Any idea what that could be...I should also add I had a busted trans mount and torque ARM mount which I replace with poly mount
Old 03-16-2014, 03:42 PM
Moderator
mrvedit's Avatar
Poly mounts amplify the tiniest problems. Replace it with a stock mount and you will likely be fine. Search this forum for "poly mount" to find dozens of similar threads.
Old 03-16-2014, 03:45 PM
01ssreda4's Avatar
Could be anything in the trans or rear honestly.
Old 03-16-2014, 03:55 PM
Moderator
mrvedit's Avatar
Yeah, a grinding noise when you let off the gas could a misaligned pinion/ring gear in the rear end.
Old 03-16-2014, 05:09 PM
boola1341's Avatar
Will any aftermarket rubber trans mount work or oem only? Does checking pinion angle require certain tools??
Old 03-16-2014, 06:46 PM
Burken01's Avatar
You need an angle finder to check pinion angle/driveline angle..
You can buy a cheapy @ harbor freight or a digital @ sears
Old 03-16-2014, 08:36 PM
Moderator
mrvedit's Avatar
There are also free aps for iPhone (and probably Android) that are surprisingly accurate.
Old 03-18-2014, 01:42 AM
boola1341's Avatar
Can a worn out tail shaft cause vibration in the driveline??
Old 03-18-2014, 02:02 AM
Burken01's Avatar
You would have to remove the DS to look at it, also Inspect the housing and bushing as they can go bad and then the DS wiggles in the housing!
Old 03-18-2014, 04:15 AM
ss performance's Avatar
I would check the pinion angle. Easy to do and easy to fix. U-joints could also be going bad, not real common but possible.
Old 03-19-2014, 06:00 AM
boola1341's Avatar
U joints replaced and vibration still there. Tailshaft replacement is next and check pinion angle. I'll update the results
Quick Reply: vibration in neutral while coasting
