removing 4l60e
removing 4l60e
ok,im pulling the transmission and am stuck.i got 6 of the bellhousing bolts out, i think there is 8 correct? i cant see them if they are there. anyone got some pics or pointers? thanks
It's 13mm, I got some wobble extensions I'm using but I can't even see the bolts. Maybe transmission isn't low enough. I'll check it tonight when I get off work.
Moderator
My trans bolts are all 15mm and when I bought a new set from the dealer, they were 15mm too.
A 15mm swivel socket will help, along with 3x 12" long extensions.
If you are sure your trans is hanging as low as the engine mounts allow (and not hung up on something), I guess you will have to remove the intake.
A lot of people don't bother putting the top bolt back in, with no adverse effects.
Did you get them? I've always used some really long extensions and if you you look from the very end of trans (tailhousing) you can see the bolts up top. If you need a hand let me know.
