th400 slip yoke/ driveshaft question (10bolt)
Old 04-18-2014, 01:38 PM
jt_2002_ta's Avatar
Default th400 slip yoke/ driveshaft question (10bolt)
Hey guys got a question about my th400 swap. Haven't measured yet but was sitting at work and had a idea. I don't really want to have a driveshaft made unless it's a must. I'm switching to a 9" soon. I know the stock driveshaft is to short so could I just get a longer slip yoke for a th400 and be ok?
Old 04-27-2014, 09:41 AM
SgtB's Avatar
get a steel driveshaft made with 1350 yokes. you will be better off
Old 04-27-2014, 11:09 AM
jt_2002_ta's Avatar
thats what i did!
Old 04-27-2014, 12:28 PM
Blowerman's Avatar
Yes ^^^^.
Not a part to shortcut on.
Old 07-03-2014, 02:50 PM
ezstriper's Avatar
no longer yoke will work, you can have the 400 done as a long shaft small output, the you only need to shorten the M6 driveshaft 1 5/8" and use the original yoke
Quick Reply: th400 slip yoke/ driveshaft question (10bolt)
