Car bogging down in all gears and wont do a burnout
Old 04-26-2014, 06:17 PM
95batmobile's Avatar
Exclamation Car bogging down in all gears and wont do a burnout
Sorry for the lame title, just started having the problem today and dont really know what to do about it.
Its a turbo car, and im hitting boost, my afr is right, everything is on point, it just wont go anywhere. Im 90% sure my trans is going out, im not really sure how to tell, so i figured i would post here.
It shifts fine, so i think it might be the stall, but thats just a complete guess, i really have no idea. It holds at about 2.5k (which is what the stall is) and it wont go faster than that to do a burnout, it will spin just pretty slow. Also in each gear as i get on it it will basically feel like a stock car pulling even though its hitting 8psi.
this is my 3rd trans, this one has lasted me about 1k miles and cost 2600 bucks from some local guy that said it would hold 500 horse power to the wheels (i make 440)....... i know... i got ripped... but whatver, someone help me
Old 04-26-2014, 06:21 PM
madmike9396's Avatar
I think you answered your own question
Old 04-26-2014, 06:32 PM
I was just asking if your guys think its the trans, sorry for not being to clear.
i checked over everything all day, and couldnt find an issue with anything, then a random thought that it was the trans, but it was just a guess.
do you think it could just be the stall since it shifts fine and all
Old 04-26-2014, 06:51 PM
did you check trans fluid ?
Old 04-26-2014, 10:32 PM
yep, little low so i put a bit in, didnt change anything. prob just gonna take it to a trans shop and see if they can drive it
Old 04-27-2014, 05:42 AM
forcd ind's Avatar
i would look at the engine tune, sum of the parts, rear end ratio, etc
sounds like maybe no low end power
Old 04-28-2014, 08:55 AM
thunderstruck507's Avatar
is it trying to start in 1st gear or is trying to start in a higher gear?
Old 04-28-2014, 10:12 AM
Moderator
mrvedit's Avatar
That is an excellent suggestion!
Have you checked for codes?
I do not recall a single thread here where "low power" turned out to be the trans unless it is in limp mode and starting in 3rd gear.
So far I don't think there is anything wrong with the transmission itself.
Old 04-30-2014, 09:58 PM
lsxstudebaker's Avatar
timming or fuel. run codes. monitor everythign!
Old 05-05-2014, 02:03 PM
sorry guys for the delayed response, i took to the trans shop and they said that it was fine, im going to pick it up in a bit.
i had the pc hooked up to it, no codes, have fuel and air, no knock, timing is on, idk what it is. I just adjusted the rocker arms in case it was the springs, but they are brand new so it wasnt that
Old 05-06-2014, 06:05 PM
bumppp any help? might just take it to a local speed shop and pay the big bucks to get it looked at
Old 05-06-2014, 07:04 PM
Cosmik de Bris's Avatar
Did you turn of the traction control?
Old 05-06-2014, 11:18 PM
no tcs on this car
Old 05-07-2014, 10:17 AM
Gingervitis Addict
slow67's Avatar
There's also a chance you hurt the sprag in the converter.
Old 05-07-2014, 02:22 PM
i got it back from the trans shop, they said it wasnt transmission related, but do you know how i could go about checking the sprag?
Old 05-07-2014, 04:09 PM
Moderator
mrvedit's Avatar
If it starts more solidly in [D1] than in [OD] the forward sprag is suspect.
Am I the only one here who suspects the converter is bad?
Old 05-07-2014, 05:40 PM
its much stronger in 3rd gear than 1st, 1st is weak 2nd gets stronger and 3rd feels pretty much fine. my initial though was the converter but idk your the only guy to say anything with me
Old 05-07-2014, 09:18 PM
Gingervitis Addict
slow67's Avatar
I did, 2 posts before this one
Old 05-07-2014, 09:23 PM
Moderator
mrvedit's Avatar
Sorry, I thought you were referring to the forward sprag in the trans. Just reading too many threads too quickly.
Yes, the sprag in the converter sounds like a good possibility.
Is there a way to diagnose that other than opening it up?
Old 05-08-2014, 01:03 AM
bfd811's Avatar
Awhhh hell mrvedit dont tell me that lol. That was the exact same symptom I was having in mine thinking that the trans go 1-2 valve was having issues.
Not trying to hijack, just making a connection. OP let us know what you find im interested to see, I might be in the same boat.
Quick Reply: Car bogging down in all gears and wont do a burnout
