what length drive shaft ?
got a 94 z with a lq based ls swap , th400 short tail , ford 9 in rearend with the 3150 yoke etc . what length driveshaft will i need ? gettin diff measurments all around .
Moderator
Are you trying to use a driveshaft from some other car or have a custom one made? If custom, measure from the middle of the rear yoke (u-joint carrier) to the back of the trans. A good custom shop is shaftmasters.com near Detroit, MI. Cost me $350 for an aluminum one; steel is probably around $275.
Moderator
