going to the track leave it in D or 3rd?????
Old 05-17-2014, 08:20 PM
ironmikektm525's Avatar
Default going to the track leave it in D or 3rd?????
Just as title says. Let me know your thoughts? And plz explain what the difference is? I have 3:23 I'm not gonna run out by end of track in 3rd? Thx
Old 05-17-2014, 08:53 PM
Moderator
mrvedit's Avatar
Its been covered in detail as here:
https://ls1tech.com/forums/automatic...-drive-od.html
In short, with a stock trans keep it in [OD].
Reason - in [D3] during the 2-3 shift the overrun clutches are also applied, bleeding pressure from the 3/4 clutch at a critical time.
The Sonnax 2-3 HD shift valve is a nice upgrade that strengthens the trans in [D3], but is non-trivial to install.
Old 05-17-2014, 09:33 PM
I googled searched it to lol. I must of not worded it right. Thx for the link! So what does all that mean? That link didn't really answer my question lol
Old 05-17-2014, 10:55 PM
Moderator
mrvedit's Avatar
In short, with a stock 4L60E leave it in [OD].
Old 05-18-2014, 07:31 AM
01ssreda4's Avatar
I prefer D myself (always have). My trans builder agrees. I've never had or seen a 4l60e failure personally by someone using D at the track. And no you won't need 4th gear at the track.
Old 05-18-2014, 08:42 AM
Anybody else? So I leave it in D or OD lol
Old 05-18-2014, 03:23 PM
JustAFooL's Avatar
I've always stayed in D. It's true what you read about the over-run clutches but I had always used it before with no problems, still do.
Old 05-18-2014, 04:18 PM
kelsey_canard's Avatar
I have noticed my 4l80e drops from around 160psi at WOT to 130psi at WOT for a brief second on the shift. Does this apply to the 4l80e also?
Old 05-18-2014, 07:33 PM
Moderator
mrvedit's Avatar
In post #4 I mention that my suggestion only applies to the 4L60E. The 4L80E is completely different and I cannot answer that.
OP: You are over-worrying. In "theory" racing in [D3] may cause the 3/4 clutch to slip/wear a tiny bit more than in [OD] with a stock trans. Since zillions of people race in [D3], as 01ssreda4 points out, the difference is negligible. Note that a performance built trans will have higher pressure and faster engagement of the 3/4 clutch, making it a mute point.
Old 05-18-2014, 08:45 PM
OD it is! Thx mrvedit
Old 05-19-2014, 06:44 AM
Hardtop's Avatar
I leave mine in OD.
Old 05-19-2014, 08:50 AM
thunderstruck507's Avatar
It is worth noting if the trans has a lot of miles/wear, racing in 3 instead of OD may begin to allow a slip on the 2-3 shift which will further increase wear and cause the car to hit the rev limit instead of completing the shift. I had this issue until I installed the HD 2-3 shift valve mrvedit mentioned
Old 05-19-2014, 09:25 AM
transam69230's Avatar
FLT always told me to race in 3rd with my 4L60E and now with my 80E I always make pulls in 3rd.
I am sure Jakeshoe or someone from FLT has some input on this.
Old 05-19-2014, 10:49 AM
LS-ONE_DAY's Avatar
I posted a similar thread a while ago, my responses IIRC, were mostly put it in D instead of OD, although, I did specify that my trans was tuned (still stock other than converter). But for more reference material....
https://ls1tech.com/forums/drag-raci...ip-newbie.html
and then more street oriented...
https://ls1tech.com/forums/automatic...ting-auto.html
Old 05-19-2014, 11:37 AM
LFSADRG's Avatar
For me, I do the burnout in 2nd then race in 3rd. Stock 4L60E.
With 3.23 gears its in high 4/low 5 rpm range. Now with 3.73's holding it in 3rd rpm's at the stripe are between 5 and 6K.
Old 05-19-2014, 07:38 PM
So warm up the tires in OD also? My trans has 130k
Old 05-19-2014, 08:29 PM
Moderator
mrvedit's Avatar
With the shifter in [D2] the trans will start and stay in 2nd gear. This is suitable for an aggressive burnout so that the trans doesn't shift from 1 to 2 during the burnout.
Old 05-19-2014, 10:20 PM
LFSADRG's Avatar
When I tried doing the burnout in OD or 3rd the engine would begin to lug since it upshifts, hence automatic trans. Holding it in 2nd allows me to regulate the throttle better.
Stock engine and trans with 100+K and used as my bracket car. At the end of season, if I keep the car, will be contacting Jake's for a proper build.
Old 05-19-2014, 10:21 PM
Pontiacerator
RevGTO's Avatar
I always start my burnout in 1st and upshift to 2nd during it. Gets the tires spinning faster more quickly with less chance for wheelhop. I've heard people say not to but I've yet to hear a convincing reason why it would be bad for the trans.
I can't see any reason for running in 3rd at the track. The car won't shift into 4th at WOT anyway. Why not have every bit of pressure possible going to the (weak) 3-4 clutch pack?
Old 05-20-2014, 02:05 AM
RonSSNova's Avatar
Ditto on the burnout. The Vette has too good of rear brakes to use second only as I don't have a line lock. Well, I have one, just never installed it......
The stupid vette also has electronic throttle and traction control. Of course I turn the TC off, have deleted all the abuse stuff, but something in that system still gets pissed off and takes throttle away on occasion during the burnout.
I have a PB level 2 trans, and have no clue if it has the Sonnex valve in it. So I race in D4 (OD to you Camaro guys)
Well over 150 passes over the last two years searching for that elusive 10.99, and the trans works as well as it did when I put it in.
Ron
Quick Reply: going to the track leave it in D or 3rd?????
