4l60e trans mount
4l60e trans mount
basically did an lt1 to lq4 swap on my 97 formula.
was about to install the transmission crossmember.
found out the trans is sitting to low in order to put the crossmember with bolts.
the crossmember lines up to the car body and bolt wholes, but since the trans is to low i cant put the crossmember on.
hopefully the pics help.
