Replacement Trans cooler fitting
Old 06-23-2014, 10:49 PM
Fat Jesus 808's Avatar
Default Replacement Trans cooler fitting
2001 Camaro Z28 with Oem radiator and 4l60e. I need to replace one of the stock transmission cooler fittings on the radiator. I think. The lower one has a fluid leak build up on it. Im getting ready to do a B&M cooler in addition too and want to replace this while im at it. Anyone know the part number or have a link? All I can come up with is the transmission fittings. Thanks
Old 06-25-2014, 02:14 PM
01ssreda4's Avatar
B+M 70264 has everything you need.
Old 06-25-2014, 02:18 PM
jsteele90's Avatar
or you could eliminate the radiator from the equation and run -6 braided lines to your trans cooler directly from the transmission
Old 06-26-2014, 11:04 PM
Thanks guys. I'll look more into this weekend while im lowering it and removing the AC system.
Old 06-26-2014, 11:12 PM
98CayenneT/A's Avatar
This, order that cooler and your good to go
Old 06-29-2014, 09:02 PM
Thats the cooler I have. Looking more and more like im going to bypass the stock setup when I install
Quick Reply: Replacement Trans cooler fitting
