2002 4l60e horsepower?
Old 07-01-2014, 03:58 AM
"I MAID THEESE"
Mavn's Avatar
Default 2002 4l60e horsepower?
How much does everybody think an 02 4l60e with a trans-go Hd-2 shift kit, 25,000 btu cooler, and billet 2-4 servos will hold?
Have the line pressure up decent high and the shifts tuned to shift fast. Been running it behind my car for 3 months with no issues. Im about to get 1 7/8 headers and 3.5" ypipe instead of my shitty eBay 1 5/8 headers and 2.5" ypipe lol should be a 10-20 hp gain over my current setup.. Just seeing if I'm getting to my max since I'm about to go fast 92.!
Old 07-01-2014, 07:37 AM
01ssreda4's Avatar
Its hard to say for sure. I've found if you limit trans abuse you're in good shape. Meaning try not to WOT into lower gears. Use the shifter to manually select the gear before you go wide open, this gives the clutches a chance to grab and hold before power is applied. Plus my builder recommends racing in D, so that's what I do as well.
Old 07-01-2014, 09:26 AM
hrcslam's Avatar
This. Avoid automatic downshifting.
The automatic downshift from 3/4 to 1/2 causes the 3/4 pack to drag because there isn't enough time for the fluid to drain out of the 3/4 clutch pack apply piston and centrifugal force uses the remaining fluid to apply the clutch pack partially.
That is why these transmission burn up 3/4 so quickly. Much faster if you're hard on it.
There's a fix though, doing the drill mod to the input drum (complete rebuild), then upgrading the steels and clutches in at least the 3/4 drum from the 6 to 7 or 8 set up (might as well do all of the clutch packs while you're in there), on top of the shift kit. Add in a hardened sun shell, a 5 pinion gear set, and you're set to hold a LOT of power.
Horsepower ratings in transmissions and axles are a load of crap really. It's not just about max power, it's also about the traction and load on the other side of it.
Old 07-01-2014, 07:21 PM
"I MAID THEESE"
Mavn's Avatar
Yeah I always manually down shift. Hold it until the 3rd honk them floor it and up shift.
Old 07-01-2014, 11:12 PM
warriorpluto's Avatar
So if I'm using circle d and I'm about to race, I shift the shifter to 3 before the race or downshift to 2?
Old 07-02-2014, 08:18 AM
01ssreda4's Avatar
^^^depends on the speed you are starting from.
Old 07-02-2014, 10:45 AM
hrcslam's Avatar
This, if you are in third it doesn't burn it up (properly built). If going to second, drop it to second manually before the honks. Even this isn't guaranteed to prevent clutch burn up though. But it does give more time for the fluid to escape the 3/4 apply piston.
Quick Reply: 2002 4l60e horsepower?
