fti 3600 help!!!
Old 07-07-2014, 04:25 PM
onefast ls1's Avatar
Default fti 3600 help!!!
I have a bolt on ls1 with fti 3600 converter just recently when I reverse car slightly moves then stops and I have to lean on converter till about 2300rpm to get the car back moving trans shop says fluid and level is fine. And also I have 3rd to 4th slip and when the converter locks it comes right back unlocked.
Old 07-07-2014, 04:45 PM
xFormulax's Avatar
Can't help ya with all of that but for the converter coming unlocked I had that problem. The reason it was happening to me was because the computer was detecting missfires in that range and was kicking me out. With the tune adjusted all is well.
Old 07-07-2014, 04:48 PM
OK thanks for your feedback I'll try the retune to see if that helps.
Quick Reply: fti 3600 help!!!
