TC intall: Pro or self?
Did most of you have your TCs installed for you or do it yourself? I'm a little reluctant to break open my tranny since I haven't before even though the install doesn't look hard at all. A friend and I did a cam swap on an LT1 just fine so the TC doesn't look hard. Do you have to get your CPU reprogrammed when you change TCs or does it just adjust?
You should be able to do it. I am not going to do my own (even though I did my own headers). You and a buddy should be fine, I looked into the install myself before deciding and it doens't look all that hard. What is the stall speed? You will need something like a hand programmer to adjust the shift points and take out or edit torque management depending on the year.
i had a well respected shop do mine and love it! even though i am going to do headers myself i would rather have something like a TC installed by a speed shop.
J
J
Come on guys...it's a hell of a lot easier than a cam install, or a shiftkit. Just make sure you have access to a lift, a tranny jack, and some really long estensions to reach the top bolts, they are a bitch to get to. You will need two people to do it. My buddy and I can do a swap in about 1.5 hrs.
Matt
Matt
Matt
Matt
