no vss signal to speedo or snap on solus scanner
Old 07-19-2014, 03:23 PM
novaskilling's Avatar
Default no vss signal to speedo or snap on solus scanner
i recently installed an L33 in my 72 nova. the motor originally had a 6 speed behind it and when i bought the motor i changed the setup to an automatic 4l60e. i started the car for the first time the other day and had no speedo reading or reading through my snap on scanner. I changed the vss sending unit out with a new one and still nothing. The speed readout worked fine with the 6 speed standard but now with the 4l60e i have nothing. Any help would be greatly appeciated.
chris.
Quick Reply: no vss signal to speedo or snap on solus scanner
