th400 to strange s60 driveshaft longer or shorter
Old 08-30-2014, 07:08 PM
vbls's Avatar
Default th400 to strange s60 driveshaft longer or shorter
the reason i ask is because i have a expensive strange driveshaft now, they told me that they can shorten it but not make it longer.. so with a s60 rearend and th400 will i need a longer or shorter driveshaft??
Old 08-31-2014, 07:21 AM
BOLO's Avatar
I believe you will need a longer driveshaft.
Old 08-31-2014, 08:12 AM
Carl at CRP's Avatar
What combination was the driveshaft built for?
Carl
Old 08-31-2014, 08:45 AM
vbls's Avatar
4l60 and the strange s60 rearend
Old 08-31-2014, 09:42 AM
First You will need a different slip yoke, 4L60 has 27-splines while the T400 has 32-splines. This means the yoke will be a different length. Then can check this chart out...keep in mind there are quite a few different length tail shaft lengths for the T400. best bet is to install the T400 and measure to be certain of the accuracy.
http://www.tciauto.com/tc/trans-dim/
Carl
Quick Reply: th400 to strange s60 driveshaft longer or shorter
