Stock drive shaft and 4l80e
Old 09-15-2014, 11:25 AM
kylemm1002's Avatar
Default Stock drive shaft and 4l80e
How many of you are using the stock drive shaft with a 4l80e? Read on here it will work with a new yoke.
Got my new yoke installed yesterday and have just under 2" of yoke showing. Everything I've read says no more then 3/4" to an 1" max showing.
So do they make a different extended yoke that will move it farther forward. Right now I just picked up a standard th400 yoke cuz that's all I could get locally.
It's a spicer I'll get the part number.
Old 09-15-2014, 03:10 PM
NorthTexasConverter's Avatar
Is it a stock 4L80E?
Old 09-15-2014, 07:13 PM
kylemm1002's Avatar
Ya a stock gm reman.
Old 09-15-2014, 09:12 PM
kylemm1002's Avatar
Here is a pic of what I'm working with.
The larger mark towards the front of the car is where the seal on the tail shaft ends. Smaller mark roughly 3/4" further back is the back of the output shaft.
Before I wasn't thinking about the rear shaft sticking out that far past the rear seal.
Old 09-16-2014, 07:00 PM
kylemm1002's Avatar
Any opinions?
Old 09-16-2014, 07:52 PM
Moderator
mrvedit's Avatar
Personally I would get the correct driveshaft made ($250 steel, $350 aluminum), but you might want to look at this similar thread started today:
https://ls1tech.com/forums/automatic...tion-help.html
The OP identified a slip yoke which is 1" longer than normal, which might fit your needs. Actually even the shorter ones have 5" of yoke.
However, wait for expert feedback because I don't know much about this topic.
Old 09-19-2014, 03:21 PM
kylemm1002's Avatar
Just to updated anyone else looking for this info.
I put it all together using this yoke and a conversion joint for the stock shaft. Ended up with about 1-1/8" of splines not engaged. Works fine so far up to 90mph. No vibrations or anything.
Old 09-21-2014, 03:20 PM
Moderator
mrvedit's Avatar
Please confirm that you indeed did use the longer yoke and if perhaps the part number.
Old 09-21-2014, 06:21 PM
kylemm1002's Avatar
I'll get the part number later but it's not the longer one. That wouldn't of helped the issue I was worry about. I already had plenty of engagement. I was worried about the unengaged section. After comparing the mine (under 1-1/4) to the stock slip yoke it had even more so I'm not worried about it.
Quick Reply: Stock drive shaft and 4l80e
