4L80E slip yoke selection help
Old 09-16-2014, 09:21 AM
tvanlant's Avatar
Default 4L80E slip yoke selection help
I need help choosing which yoke I need since there are several lenghts.
My driveshaft uses 1330 u joints.
I removed my tailshaft housing and from the end of the shaft to where the splines end is 5". There is NO o-ring on the shaft. The shaft has a threaded hole in the end.
Looks like these are the shafts to choose from:
http://www.summitracing.com/parts/so...31hp/overview/
5.500" length
http://www.jegs.com/i/Spicer/094/2-3-10831X/10002/-1
6.760" length
http://www.jegs.com/i/Spicer/094/2-3-14831X/10002/-1
7.720" length
4L80E output shaft
4L80E output shaft length
Old 09-16-2014, 04:12 PM
Moderator
mrvedit's Avatar
I think the first two are the same length.
The 6.76 is from the end of the slip yoke to the center of the U-joint:
http://www.northerndrivetrain.com/pr...-3-10831X.html
Wait the confirmation, but with a proper length driveshaft, either should be fine; the longer one might not even fit.
Old 09-17-2014, 11:58 AM
tvanlant's Avatar
Well, I will give the Spicer 2-3-10831X a shot
Quick Reply: 4L80E slip yoke selection help
