ms4 cam only stall size
What size stall you guys using for your ms4 setups? I am thinking 4200ish.. have a 3600 stall but thinking of getting it restalled to a higher setup. How will it act with the 3600 in it? This isn't a long term setup nor daily driven. 3.73 rear gear
Im right behind you with the MS3 and im running a 3500 stall 10" converter w/ lockup and im pleased with it. When i used to sell hi perf transmission products i would recommend no larger than a 3800 to guys with the ms4 (depending on there setup) and all seemed pleased with it.
