Tourqe converter bad outta box? Please help
Old 10-07-2014, 10:01 AM
HomeSchool's Avatar
Default Tourqe converter bad outta box? Please help
Well its been a long hard road but I finally got enough time off of work to finish putting my rebuilt tranny back into the Tras Am and fire it up. When I started it up the first thing I heard was a LOUD clicking/clanking noise coming straight from the TC/flexplate area. Has anyone else experienced this? or know what it is? It sounds like the flex plate hitting something but I know there isn't anything in the way. Is it a bad TC? I filled it with tranny fluid before I installed it. I thought it was the Pump stator in the transmission but no noise is coming from the transmission, and I have both forward and reverse. Any input would help. the torque converter is an after market Revmax built to 3200 stall, installed into a 96 lt1.
Old 10-07-2014, 11:00 AM
01ssreda4's Avatar
Are the torque converter bolt heads hitting the motor and the flexplate turns.
Old 10-07-2014, 11:23 AM
Circle-D's Avatar
Cracked flexplate can make strange clicking noises. If it is converter, it will usually change tones or even go away when in park vs drive. Any difference there? And like 01ssreda4 said, make sure the bolts have clearance from the block. If you are running the stock flexplate you are probably ok there.
Chris
Old 10-08-2014, 02:41 PM
HomeSchool's Avatar
Okay I figured it out. The torque converter was too far from the input shaft and too close to the flex plate. After rigging up a quick fix with some washers and some bolts from the hard ware I seated the TC back nice and snug and fired it up bam, no more noise. Soooo now my question is should I buy a flex plate spacer to make up for the gap or a TC spacer? I don't want to run the car with a rigged up TC like it is, I don't think the setup will hold up to alot of driving for very long.
Old 10-08-2014, 04:40 PM
Moderator
mrvedit's Avatar
When the converter is not bolted and pushed toward the trans, what is the gap between the converter pads and the flexplate?
Old 10-10-2014, 03:07 PM
01ssreda4's Avatar
^^^^that....
Old 10-11-2014, 07:38 PM
HomeSchool's Avatar
Sorry for the wait. The gap is half an inch with the converter pushed all the way back.
Old 10-11-2014, 07:59 PM
Moderator
mrvedit's Avatar
Half an inch is a huge gap!
Please confirm this is an LT engine and a 4L60E trans.
Hopefully Circle-D or other expert can give you some good advice. It doesn't sound like a properly built or model converter to me.
Old 10-11-2014, 09:42 PM
Circle-D's Avatar
Did you measure it at a half inch or did it look like a half inch? And is this the stock transmission, flexplate and motor? Can you take some pics and post it? Might have a mismatch on parts. Half inch is way off and to much to shim.
Chris
Old 10-13-2014, 05:40 PM
HomeSchool's Avatar
It is measured half an inch gap yes. the transmission is a 4l60e that was just rebuilt, the converter is a after market Revmax, one thing I did notice is the stock Torque converter has little "nubs" that bridge the gap a little bit, while the after market one does not. I'll have some pictures soon
Old 10-13-2014, 07:48 PM
Circle-D's Avatar
Pictures would be great. Need converter from a few angles and trans bellhousing area. Still running the stock motor and flexplate?
Chris
Old 10-13-2014, 08:23 PM
HomeSchool's Avatar
Yes the engine is a LT1 with the stock flexplate. The engine isn't stock but I cant think of anything that would affect the flexplate/rear engine bay area. The only mods are Just headers, exhaust, injectors, and thats about it.
(And before anyone asks, no I didn't add injectors thinking i would gain horsepower from an other wise bone stock setup. My stock multecs were going bad)
Old 10-18-2014, 06:23 PM
HomeSchool's Avatar
All right sorry for the wait, been banking some OT. Heres some pics
Theres the half inch gap
A shot from the bottom
A few angles
Angles...
View from the back
Earlier today when I got home i threw the bolts and washers back in and now its making more noise then ever. I don't understand the problem and now I'm lost again
Old 10-18-2014, 09:47 PM
bbond105's Avatar
Is the trans the one that came with the car and engine? If so why not call Revmax for tech support? I would say you either the wrong trans, TC or both for your engine.
Old 10-19-2014, 09:37 AM
Circle-D's Avatar
Looks to be a 4L60 LT style trans with the open bellhousing. And the 4L60 LS style converter is to tall, so you probably have the right style converter. With 1/2" of converter clearance something sounds way off. You could be pulling out of the crank when you add all the spacers, so the converter is not centered. I agree with the previous poster, give Revmax a call. Something is not right.
Chris
Old 10-19-2014, 07:57 PM
HomeSchool's Avatar
Thanks for all your help guys, I'll be sure to give revmax a call, and keep this thread updated as things progress
Old 11-04-2014, 02:42 PM
HomeSchool's Avatar
Whelp I called revmax, they said too measure the height of the converter to make sure it was the same 5.9 inchs as the stock LT1 converter. Well it is, dialed right where it needed to be on the micrometer. I really don't understand whats going on. The engine runs fine no ticks or noises so the crank hasn't moved. The Transmission bell housing is a part of the case there is NO WAY that could have changed. when the transmission was rebuilt I reused all the factory shims and thrust bearings and the the input shaft hasn't changed height and length either. simply out the gap should not be able to be there at all. what now?
Old 11-13-2014, 02:25 PM
LS1Tech Sponsor
FTICONVERTERS's Avatar
It looks like you have the small diameter flexplate and the converter mounting ring maybe hitting the ring gear before it touches the flexplate.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old 11-15-2014, 09:19 PM
bbond105's Avatar
Looking closer at the pics I think Greg from FTI is on to something.
Old 11-17-2014, 08:30 AM
Circle-D's Avatar
Can you get 2 measurements? One from the block to the flexplate converter surface. Second from the bellhousing to the converter pad.
Chris
Quick Reply: Tourqe converter bad outta box? Please help
