Exedy vs Borg vs Alto vs Raybestos Clutches on 4L80E
Which clutch will be better for my 4L80e? I have kinda compared the Borg vs Alto and Borg vs Raybestos, but have not compared Borg vs Exedy. I am leaning towards Borg because of the ability to soak up more fluid compared to others tested. What are you guys running?
All the TH400 & 4L80E clutches that I carry in my kits for 2nd and 3rd (direct) are Borg Warner Hi-Energy and the rest are Borg Warner. Jake for his builds uses the same here. They do everything well as far as longevity, holding torque & horsepower and there tolerances (as far as run out per clutch) are much closer than Raybestos. Altos just do not do what we want from them. Inspect the clutch closely for run out before using it. Even Borg Warner has had "bad runs" over the years. The same goes for the steel clutch plate.
That will give me the most accurate idea for price and I can help you from there
