Best way to drain 4l60e
I need to know the best way to drain all fluid from my trans so I can ship it. The trans it out of the car already.
I was going to pull the pan then hang the trans from my cherry picker and let it drain out of the tail shaft over night, but could use some more help on this one.
Moderator
The OP's idea of hanging it tailshaft down will help drain more out.
You really need different positions to get most of it out.
"Closed" areas like the accumulators and servo will hold ATF regardless.
Moderator
Put a durable "NO FILTER!" label on the trans if you leave the filter off during shipping. You or the recipient don't want to overlook that when it is reinstalled.
