Trans temp sending unit and teflon tape
I'm in the process of installing a few gauges in my car, one of which is a trans temp gauge. I have the sending unit installed with a little teflon tape on the threads, since that's what the Autometer instructions said to do. I've just read a few threads on different forums stating teflon tape should never be used. Should I removed the teflon tape and use high temp RTV instead?
Moderator
The concern is tiny bits of tape coming loose. I don't use teflon tape in the fuel system because even the tiniest bit would clog an injector. Don't think a tiny bit would hurt the trans; be careful not to let any tape past the threads which might cause a bigger piece to come loose and clog a valve.
Where and how are you mounting the temp sensor?
im about to install a trans temp and fuel pressure gauge. would rtv be a better option like op asked or just make sure the tape doesnt go to far into the threads???
If you install the Teflon tape correctly, you should never have a problem with the tape getting into anything. It works very well. I have been using it when it used to cost over $10.00 for the little roll of it.
