Is my flexplate spacer in the correct spot? Th350, pic inside
5.3/th350. Bought already swapped. Pulled the trans to swap converters and like a dumbass, after tightening the bellhousing bolts down, I realized the converter was tight and wouldn't spin freely. Didn't measure the converter yet to see if it was all the way in the trans, but I'm pretty sure it is. I pulled the trans and converter back out and the face of the converter feels like it has trouble sitting flat against the face of the flexplate. Is that spacer on there backwards?
You are using the spacer as more of a crank extender, not to space the flexplate. So it might be right, depends on what the converter needs. You might of had a problem and the converter was not stabbed all the way into the transmission. Can you measure the converter pad to bellhousing distance, should be just over an inch? Also snag a pic of the converter from the engine side, we can tell what pilot it has and if you even need the spacer.
Chris
Chris
I dont know if that will help. The issue isn't getting the flexplate to converter gap under control, the issue is the pilot area of the crank/converter. My converter is getting pushed into the pump. As long as you keep that spacer in there the way it was, it wont matter where the flexplate is, the converter will be into the pump too far. I pull the spacer out and the snout on the converter JUST BARELY hits the crank. I could get the pilot on the converter extended, or cut my spacer down some, but Im worried about having ENOUGH of the converter snout in the pilot. How far should the converter pilot be in the crank?
Either that, or I didnt have the converter seated all the ways to begin with. Although, I find it a coincidence if that is the case AND the spacer is wrong too.
It's not. Its right at 1/4" past the pads. Probably only 1/2" of usable snout total. Would you say that 1/2" is needed to be seated in the crank properly? How long should the snout be overall?
So, this is likely setup for a gen one with the pilot only entending 1/4" past the pads? I'm thinking about turning my spacer down ~.300 and adding in a spacer to take up the gap in the flexplate. I think that would get me close to where I would need to be as long as have enough room for the pilot to go either way.
Ok well the seller pm'ed me back and this converter is for a sbc/bbc to th350. So that is likely the issue with the pilot, but shouldn't it work still with the flexplate/spacer I have?
