rebuilt 4l60e with new converter shudders on lockup
Old 01-02-2015, 05:30 PM
IamSam's Avatar
Default rebuilt 4l60e with new converter shudders on lockup
Just did a rebuild on a 4l60e with a new converter from transtar. I installed the superior shift correction kit (4l60E-L) as well. I have built a few 4l60E's and have never had someone come back to me complaining about a shudder. I went for a test drive and sure enough.. it shudders when the TCC locks up.
According to the shift kit, the powervalve sends more fluid to the converter clutch than the stock valve. I told the guy he would need a new converter. Being a bit paranoid that it may be my fault, I would hate to have the guy replace his converter and still have the issue. To some of the other experienced trans guys, what should I check before I tell him to return the converter?
It shifts great in all ranges. No contamination on the fluid. It dosent feel like a misfire. I havent checked line pressure, but I doubt ill have an issue with that. Anything else anyone can think of? I may just be overthinking it!
Old 01-15-2015, 08:12 AM
JKB315's Avatar
My converter does the same thing . I figured it was just in its way out.
Old 01-15-2015, 11:02 AM
Snap-On's Avatar
If the tcc valve isn't worn, it's probably the converter piston cracked. I recommend the tcc fix by dr. Tranny, it cures most shudders
Old 01-27-2015, 12:18 PM
gto65lvr's Avatar
if its a stall converter you will need to tune the shift/lock up MPH to a higher MPH and retest until it goes away and locks when best for DD driving.
Quick Reply: rebuilt 4l60e with new converter shudders on lockup
