My T56 to 4L80E Build
#44
Gotcha. So do you think that would work with a t56 harness? The way i understand it right now.... and this confuses the **** outta me. The speartech harness plugs into the t56 harnes and then plugs into the 80e connectors? So it then converts it to a manual VB?
#46
Oh ok i see. Yea i can see how my previous post can be confusing haha. I know my answer to what i was trying to ask now. I really want to try and avoid messing with to much wiring so i am going to just buy the speartech harness i think.
#49
Hey Dementia, how are things going for you. I am about to throw the Trans in and button everything back up. I have been taking pics and will probably make a thread once im closer to being done.
#50
Sorry things have been slow for me in my quest for parts. So far I have the following:
Jakes stg 5 4l80e
FTI 10in Triple Disc Converter (3600 stall per FTI's recommendation)
B&M Pro Stick Shifter
Mezier FP319 Flex Plate w/ ARP Bolt kit (awaiting delivery)
B&M 4L80e TA relocation crossmember (awaiting delivery)
Energy Suspension Torque Arm Bushing (poly)
Dragging my feet but probably about to bite the bullet on a CompushiftII within the next week. Initial wants were to get this with paddle shifters but after reading around, I'm opting for just the controller as I dont want to feel the wrath of the insurance company should i ever need them in an accident and they realize that I removed my airbag to go with paddles on an aftermarket wheel.
Once thats purchased I guess i just need a couple more small things. Please let me know if I'm forgetting anything:
Harness (If I'm not mistaken I wont need this as it looks as though the CompushiftII comes with a harness)
Tranny Bushing (Just thought of this as I bought my crossmember could use opinions quick on rubber or poly on this part. thinking rubber as I already have poly motor mounts and all poly might cause more vibrations than I want - not sure though)
Transmission Cooler - B&M Super Cooler/Oil Cooler 70274
Braided Line/Fittings (Could use some rough guestimates on how much line I'll need and a good place to buy them. Wanting to stick with my ultimate plan of black braided lines with aluminum/bare metal finish fittings.
Dipstick & tube (really need help on where I should get this at. researched a bit and it seems as though I just hear horror stories)
Some materials to fab up a shifter hole block off plate/mounting surface.
NnOoSsSs - hows your build going man? I'll try to find a thread if you've started one yet as I realize I'm late in replying to your post (sorry guys been a rough couple of months for me). Hope thigns are going well and I definitely look forward for some pics. I still like to think I'll be able to do this install all by myself but with as little free time, limited space, and general lack of the proper tools for whatever job that seems to be at hand, I have a feeling I'll end up taking it in to my local performance shop.
Jakes stg 5 4l80e
#52
Hey man things are coming along slowly for me also but i hope to finish thing up in the next couple of weeks. I will take some pics and share them with you i do have a thread in the trans am section but i think it died so i will probably make one in this section.
#53
Mezier plate, bolt kit, and BMR crossmember arrived tonight. Plate and the crossmember look fantastic but the bolts I received are Mezier bolts and not ARP bolts that I had asked for when I ordered.
Researching it, the Mezier bolts look to be rated at 170k PSI tensile strength whereas ARP bolts are rated at either 180k or 200k PSI depending on the varying levels they carry.
Do you guys have any experience with Mezier bolts? Are they strong enough for 850-1500hp? I'd appreciate any immediate input as if I need to return these I'd rather do that sooner than later.
#54
Compushift2 is ordered finally. Confirmed with the makers and it includes all harnesses with it so I can x that off my list as well.
Next up tranny cooler and lines, dipstick and tube, and tranny mount.
Started a thread on the tranny mount but got 0 traction on that. Going to play it safe and go with rubber mount. Looks like that's going to be AC Delco part#22174970.
Have:
Jakes 4L80e stg5
FTI 3600 triple disc billet lockup convertor PMLS4-15B-3
Mezier billet flexplate FP319
Mezier flexplate bolts
BMR tq arm relo crossmember BMR-TCC021
Energy suspension Poly Torque Arm bushing 3-1111
B&M Pro Stick Shifter BMM-80706
B&M tranny brackets&levers BMM-75498
B&M neutral reverse safety switch BMM-80609
CompushiftII (pending delivery)
Need:
Tranny Cooler
Cooler Lines & fittings
Dipstick and Tube
Rubber tranny mount
Does it sound like I'm missing anything at all? Also any recommendations on dipstick and tube?
Have:
Jakes 4L80e stg5
Need:
Tranny Cooler
Dipstick and Tube
Rubber tranny mount
#55
Have:
Jakes 4L80e stg5
Need:
Tranny Cooler
Dipstick and Tube
Rubber tranny mount
Have:
Jakes 4L80e stg5
Need:
Tranny Cooler
Dipstick and Tube
Rubber tranny mount
#59
NP for the part number on the shifter. It feels like a great piece. I also ordered the aluminum shift **** for it with the phoenix. Had to buy some adapters to make it work but i love the way its going to look. The adapters are a little on the small (read short) size so i'll be brazing 2 of them together but it should come out perfect.
#60
