Tci ez tcu auto swap
Old 02-07-2015, 06:24 PM
350pride's Avatar
Default Tci ez tcu auto swap
97 corvette auto swap using Tci ez tcu
Issue: trans will not shift out of first. Tci unit is reading proper RPM and tp, but will not register correct speed. When running 35 mph it only reads 9mph.
We wired the unit to the vss on the rear diff, and we have tried it wired to the ipc.
Any help would be appreciated. This is the second unit we have received from TCI and we are short on ideas.
Thanks
David
Old 02-08-2015, 05:25 AM
BigVin's Avatar
Thanks
David
disconnect the vss and try that. You should do this with the car on jack stands so there is no load on trans
Quick Reply: Tci ez tcu auto swap
