Mounting TH350 To 5.3 - Are my parts correct?
Hey everyone,
Gonna be doing an LS swap soon, and I'm keeping my TH350. Just checking that this is all I need, and if you used something different to mate your LS to a TH350/400, please share what items you used!
So, assuming I will be starting with an 02 5.3, which has the dished flex plate, I would nee..
From GM Parts Direct:
Spacer: 12563532
Bolt: 19257940 (anyone know if this is for one bolt or 6?)
and then I'll have to elongate the holes a tad. Is that it?
Also, Summit sells this spacer, too:
http://www.summitracing.com/parts/hup-hp3795
But I would still need bolts for that, and it's $13 more than the GM spacer.
How am I lookin fellas, all good?
Spacer: 12563532
Moderator
Go with the the GM spacer which bolts in; I recall a few complaints about the Summit spacer rattling around and causing noise.
According to my notes you need 6 of those bolts. I recall a kit on Summit that included the GM spacer and the 6 bolts at a slightly better price, but I cannot now find it.
