tci flexpate install question for th400
yes. the converter has a longer pilot extension than "normal converters. With the shim still bolted to the back of the flexplate, that makes the bellhousing side of the flexplate flush with the end of the crank pilot. Sound correct?
I would need longer than flexplate bolts then, correct? there is only about .480 of threads threw the flexplate.
Thanks
Thanks
Can you post pics of this setup. I just got done with this exact swap and didnt need a crank spacer. But I went from a 98 dished to the TCI 399753 if that makes a difference and a ls specific concverter
