Question about flex plate I just got in the mail
So I ordered a flex plate from a sponsor on here and when I got it in the mail it says TCI 399754 for 4l80e..... Now here's my problem.... I have a 408 with a th400. I called them and they said it works. Does anyone else have any insight on this bc I want to be sure before I put this on and put the motor back in the car.
Depends on what bolt pattern the converter has. You can do a quick test, set the flexplate onto the converter to make sure the holes line up. The 399754 has 6 holes on the big 11.5" bolt circle. Other thing you need to worry about is the converter pilot, you might need an extension if the converter was built with the normal TH400 offset.
Chris
Chris
Well I haven't even ordered a converter yet . The car is all taken apart and just a roller right now. I just didn't want to slap the flex plate on before I new and then end up having problems. The car also has a 91mm turbo. So i just need a little insight before I order the converter from you guys.
Chris
Because of our custom CNC capability, we would not need to use a spacer. Ask for our LS dual front cover. This incorporates the long LS pilot with 6 lugs on the 11.5" big gm pattern. Have your cake and eat it too.
-Brian
-Brian
Moderator
Just to clarify, the need for a spacer has nothing to do with the choice of flexplate. The LS crank (with a few exceptions) is about 1" shorter than a SBC/BBC crank with respect to the back of the block. Hence the need for a spacer when using a trans originally designed for SBC or BBC. GM makes the spacer (and longer bolts) which bolts on after the flexplate and provides a solid mounting area for the converter's pilot. GM uses it in some applications.
CircleD's ability to make a custom converter (at little or no extra cost) that doesn't need a spacer and has the desired mounting holes is one of many advantages of getting a custom converter instead of an off-the-shelf one.
However, if you are think you might sell that converter some day, I would suggest getting a stock pilot length and installing the GM spacer. I think it would be easier to sell a stock TH400 converter than a custom one that would only fit LS engines. Obviously your call.
Mrvedit thanks a lot for clearing a lot of that up for me. What you said makes a lot of sense. I would have not thought about something like that. I'll be ordering one soon and as soon as I do I will be starting a build thread. Thanks again
