4l60e to 4l80e
Old 03-22-2015, 03:29 PM
ISOrabbitsfoot's Avatar
Default 4l60e to 4l80e
Ive found a shop in knoxville tn that can do the 4l60e conversion. They are going to charge $1,350 for labor alone. The provided parts will cost around $2,200 they said. The finished price would be around $4,000 according to them, does that seem pretty steep? The provided 4l80e costs 1,200 with a 6 month warranty and has 85k miles. Even with that price, should the rest of the parts needed to complete the conversion cost an extra 1000 dollars? If not, where can I buy the needed parts so I can save some cash. Thanks for the help.
Old 03-22-2015, 06:33 PM
FormulaTA327's Avatar
Are you providing your own 4l80 or using theirs? Il end up spending maybe a little over $4k on my conversion. That's counting tune, their core, harness, tci flexplate, converter, Trans crossmember, new Trans cooler and yoke.
Old 03-22-2015, 08:24 PM
They are providing the trans. Just seems like I could buy the parts necessary a lot cheaper than they are charging.
Old 03-25-2015, 03:34 AM
Yea you probably could buy the parts cheaper, they gotta make their profit.
Old 03-25-2015, 08:37 AM
Moderator
mrvedit's Avatar
After reading the 320+ posts in the following thread, you might find $4000 reasonable:
https://ls1tech.com/forums/automatic...l80e-swap.html
Get it in writing that the job includes the proper harness and tune to properly shift the 4L80E. Also new cooling lines and a large external cooler mounted in front of the radiator. Also make sure it includes a quality aftermarket converter and not an OEM one. Quality 4L80E converters are $750++.
Quick Reply: 4l60e to 4l80e
