What flex plate to use with my Circle D converter?
Old 03-24-2015, 10:29 PM
jt76's Avatar
Default What flex plate to use with my Circle D converter?
I have this converter for my 4L80 swap on my T/A:
http://www.circledspecialties.com/p-...converter.aspx
Pro Performance Stage III Billet Multi Disk Torque Converter
Converter Diameter - 245mm - 9 3/4"
Having a bit of an issue finding a flex plate that fits this pattern, was wondering if anyone here uses this converter and can point me in the right direction? Thanks.
Old 03-24-2015, 10:54 PM
blackeastbeast's Avatar
I use the same converter circle d sells the flex plate for it.
jt76's Avatar
I sent them an e mail and got no response yet... have a P/N or could you link me? Thanks.
Old 03-24-2015, 11:18 PM
FormulaTA327's Avatar
Do you know if it's a 6 bolt converter of 3 bolt. By default that converter is 6 bolt. TCI makes a flexplate for the ls1 to 4l80 with the 6 bolt pattern and another one for the 4l60 pattern. 6 bolt one is....http://http://m.summitracing.com/parts/tci-399754
Old 03-24-2015, 11:20 PM
This one is for the 4l60 pattern http://http://www.ws6project.com/use...tci-flexplate/
Old 03-24-2015, 11:22 PM
jt76's Avatar
Its a 3 bolt
Old 03-24-2015, 11:24 PM
Then the last post I posted would be a good choice then
Old 03-24-2015, 11:33 PM
Here's the converter bolts if you didn't know already....http://http://www.texas-speed.com/p-...4l60-4l80.aspx
Old 03-25-2015, 10:19 AM
Circle-D_Brian's Avatar
I was looking for an email and didn't find it, but regardless it seems your question has been answered. Assuming you have the 3 bolt LS front cover on your converter, you can use the TCI 399753, or any LS SFI spec flexplate. There are lots of options here. It's the other way around that is limited in flex plate choices. That said, I'm assuming it is going in your turbo trans am in sig or no?
-Brian
Old 03-25-2015, 11:31 AM
jt76's Avatar
-Brian
I used the "contact us" feature on your site, either way thanks for answering the question here i appreciate it!
Im totally new to autos so this is fresh territory for me. The converter i have is the one i linked to in the first post. There are 3 mounting points on the converter where it bolts to the flex plate, its aprox 9.5 inches between them.
Yeah, car is the TT trans am
Old 03-25-2015, 12:05 PM
We typically reserve the 245mm diameter for the naturally aspirated, nitrous and centrifugal supercharged applications. The 258mm I believe would be a better match to a twin turbocharged 370 torque curve. We could most likely do the diameter change utilizing your billet parts, but I would need the serial number on the converter to be totally sure.
-Brian
Old 03-25-2015, 03:35 PM
jt76's Avatar
-Brian
Ugh, I bought it from a guy here that said he had it on a TT GTO. I will have to get the serial next time i am over at the shop.
Old 03-25-2015, 04:43 PM
If you are much past 700 at the tire (I imagine you are), the 245mm is just going to be too loose at the top of first and not have enough rpm drop on the 1-2 shift. You can lock the converter in 2nd and third since you have the multi disk, so that is working in your favor. You may just get it all together and see what your thoughts are then we can re think diameters and such.
-Brian
Old 03-25-2015, 05:03 PM
jt76's Avatar
-Brian
With the 6speed in there i was at 848 at the tire on a mustang dyno.
If i were to try this one out, what would be the flex plate use, just to confirm. The TCI one you mentioned above said not for use with 4l80 trans on multiple listings i saw for it?
Old 03-25-2015, 09:20 PM
It says not to use with 4l80 because it had the bolt pattern for a 4l60 converter.
Old 03-25-2015, 09:22 PM
Since your 4l80 converter is coming with the 4l60 face it will work with that plate.
Quick Reply: What flex plate to use with my Circle D converter?
