4L80E Swap - Converter and Flexplate Questions
Well, my 4L80E swap (2010 Camaro with LS3) is progressing. I can see the light at the end of the tunnel! I have some questions/concerns about my torque converter mating up with my flexplate. I have the TCI flexplate (TCI 399754). I assume that I will be using the included spacer on the end of the converter?. I dropped in my new North Texas Converter and I measured from the trans housing face to the bolting pads and it came out to 1 1/8". That tells me the converter is seated fully. I lift the trans up into position and it looks like the torque converter bolt pads are really far from the flexplate. I have never messed with an LS engine before, but on SBC's and BBC's, the bolting pads are usually around 1/2" from the flexplate and you just slide the converter out a little to match. This looks like it will be closer to 1" away once the bell housing bolts are tightened. That seems like a problem to me.
Anyone have any thoughts? (The flexplate is in with the sticker facing the right direction)
The bolt pads on the converter should be 1/8" to 5/32" from the flexplate when the trans is fully seated on the block. Put the flexplate on the crank and measure from the block mating surface to the rear of the flexplate.
It should be about 1". If not, the flexplate is probably incorrect. The 1 1/8" measurement that you have is correct for the trans/converter fit.
I am not familiar with the TCI plate that you have.
