Time for a new trans.
Old 04-18-2015, 07:34 AM
superlazy's Avatar
Default Time for a new trans.
Sadly I pretty much lost 3rd & 4th gear on my 98 WS6 with 191K last night.
I called the local trans shop and was quoted $1700 for a standard factory rebuild. Anything special I should ask them to do? Higher stall & that sort of thing. Can a regular trans. shop reprogram so it shifts into 4th @wot?
Yes I know silly questions but I just want my ducks in a row when I call them Monday to set up the appointment
Old 04-18-2015, 07:49 AM
ragtopz28's Avatar
I would get a built one from one of the sponsors >>>>>>>>>>>>>>>>>
Buy what ever "level" your mods dictate. Probably cheaper than having 'some shop' charge you for performance upgrades on top of the $1,700.
Old 04-18-2015, 08:03 AM
superlazy's Avatar
I really don't have the time or desire right now to pull it myself that's why I'm taking it to them
Old 04-18-2015, 07:17 PM
ragtopz28's Avatar
Alllrighty then. If it's your DD, I understand. If you had the time you could get a much better trans for the same if not cheaper. GL
Old 04-18-2015, 08:50 PM
Moderator
mrvedit's Avatar
Have them use a 4L65E rebuild kit as that has 7 frictions for the 3/4 clutch; it is the only difference from a 4L60E kit and therefore can always be used. Costs about $10 more.
Also have them install the Sonnax 4L60E-LB1 boost valve; distributor TranStar carries them; about $30.
Old 04-19-2015, 02:26 PM
superlazy's Avatar
Thanks guys. Yes its my DD this summer
Old 04-19-2015, 03:08 PM
Pontiacerator
RevGTO's Avatar
No better time to put in a good converter than when it's coming out anyway. I'd also go with a Transgo HD-2 shift kit, especially if you go the high stall converter route.
If the shop has a tuning tool or works with a local tuner, then they can reprogram your shift points as desired.
Old 04-20-2015, 05:09 PM
superlazy's Avatar
Go figure, drove 20mi to the trans. shop today and 3rd & 4th worked just fine. Granted I didn't jump on her too hard. Maybe if I'm lucky it will be a inexpensive fix.
Quick Reply: Time for a new trans.
