4l80 yoke help!!!
Old 04-25-2015, 01:48 AM
Justinktm's Avatar
Default 4l80 yoke help!!!
ive read thread after thread and tried 3 different yokes i just cant figure out what i need. the car had BAD vibration when i drove it with the cut th400 slip yoke so i went and got a counter bored th400 slip yoke and still not enough spline only thing that stops the small leak on the back is when i put the 4l80 yoke in it and it fells like it locks at the very end. so what should i do ? its stock driveshaftt in 2000 camaro with 4l80 and ford 9inch
http://vid102.photobucket.com/albums...psi7n4sc1f.mp4
the black mark on tape measure is where the rear seal is on the yoke so its only in there a little over an inch
Old 04-25-2015, 07:18 AM
FormulaTA327's Avatar
It looks like you might need a longer driveshaft, the 9" already makes the stock shaft to short. I thought I seen where they do make a longer yoke though, could have been on summit. Also there are 3 or more different yokes for the 80 too. Good luck man, I'm in the process of doing the same swap you are doing.
Old 04-25-2015, 07:57 AM
Moderator
mrvedit's Avatar
I have no personal experience, but here are 3 threads on the subject from last year that might help:
https://ls1tech.com/forums/automatic...tion-help.html
https://ls1tech.com/forums/automatic...-question.html
https://ls1tech.com/forums/automatic...se-advise.html
Old 04-25-2015, 02:48 PM
Justinktm's Avatar
I just can't figure this out cuz I don't see how mine isn't workig it's worked on other peoples setups I just don't wanna have to get a custom driveshaft with money tight right now I hated spending 100$ for the one yoke I gotta return now
Quick Reply: 4l80 yoke help!!!
