4L80E swap Problems
4L80E swap Problems
Can you please look over this tune and verify that the segment swap did go through...?The car will start out in second gear from a stop( In drive on the selector) the car moves 15-20ft and will shift straight to third and lock the converter, to the point the engine will stall,feels very violent as if it were going to reverse.Feels manual 1st has nothing just revs,scanner says its in 2nd gear from park to 1st ?
I hooked the scanner to the car and commanded the car to stay in first and second with good results but as soon as I let the tune control the car it will act up, when the car shifts it does not see the mph to shift, seems to shift on time.Does the rest of my tune look ok ? Thanks guys
70 Nova LS402
10.7 comp
PRC L92 heads
Comp cam 650/650,249/269,113+4
Holley Hiram 102/102
Gonna be spraying around a 300 shot through the money maker setup in the intake
3.75 rear gear
Fully built 4l80,Jake's t-brake D-3
,PRC lockup converter 4500 on motor
3200 race weight
70 Nova LS402
10.7 comp
PRC L92 heads
3.75 rear gear
3200 race weight
