3600-4k stall on stock 4l60e?
After doing a lot of searching, I'm trying to get some more input on whether to build up my 4l60e before doing a Ss3600 or ss4000 stall. My transmission was recently rebuilt after the previous owner blew it and I believe all new clutches were put in. My original impression was run the trans go shift kit(not 100% sure on which level), b&m 29k gvw cooler, and a deep trans pan and I would be good to run either converter. I plan on getting a gauge to monitor Temps also. Any opinions on this set up or other parts to upgrade to keep the trans more reliable long term? I just have seen a lot of mixed opinions and would like to see what everyone else's experiences are that run similar set ups. I ran the ss4000 in the past but not long after sold it, so never really seen the test of time. I appreciate any and all feedback. Thanks!
No necessarily true. Move that cooler a few inches from the radiator and watch temps skyrocket. Because of how yours in mounted it utilizes the radiator fan for airflow. The exact same parts setup in a different location would fail miserably without a fan. So yes, a fan absolutely is required.
Will a tune with fan set point adjustments and a 160 stat be enough for a radiator mounted cooler or would it be better to play it safe with an slp manual fan switch? Or scratch that idea completely and mount it on the condensor? I'm still not 100% sure how I want to set it up. I'm thinking I will bypass the factory cooler though. Any other input on this?
Whats the difference between a condensor mount and a radiator mount? Im not understanding that comment.
Some people are saying they are mounting on their AC condenser and others on the radiator. I'm not really sure what the difference would be?
I think from searches and other threads I'll just mount it on the inlet of the radiator and with a 160 Stat and tune for fan set points it should be good. If not I'll go further and put a fan on it. Thanks guys
I have a Yank 3k stall (2.5 str) coupled to 3.73:1 rearend gears.
I have a transgo shift kit (set to hard shift) and a Superior Race grade 2-4 servo.
I also have a 24k BMR trans cooler (mounted dope style) and a 3 1/2 quart deeper pan BMR (not recommended for lower vehicles).
I have had this setup for over 12 years with absolutely no problems.
If I had it to do over I would have gone with a 3600 stall.
