4l80e hangs right before WOT shift point, No shift at WOT
Car won't shift at WOT unless i back out of the pedal a bit. 100% to 38%
turbo fbody, 4l80e swap. 408 etc yada yada.
car is driving me nuts, would like some input..
things i've tried so far.
added/subtracted lead time using Bluecat trans tool
checked fluid, fluid is good.
level is good.
checked transmission connections, connections are good.
Would appreciate a little bit of help.
attached are my config file, tune file, and log.
level is good.
Update.. Transmission was gone through and was good. Went ahead and refreshed with new clutch pack and band
Problem still persists. Have checked continuity on all transmission wiring
"On a 1-2 shift issue I would look at the tune first , i know your ajusting the MPH tables but what about the RPM I would lower both. If that does not fix it you have a trans problem that a shift kit will not likley fix .Burned band likely." (Perfomabuilt trans)
This is exact what my 4l80e is doing and what I have done to try to correct it. Looks like a rebuild or purchase is in my future.
A pump bushing walking out doesn't really seem to make much sense at all as to why it wouldn't shift
And if the trans was checked out...that should have been caught anyway?
The following users liked this post:
grasshopper645 (07-30-2019)
