3/4 accumulator spring
When I tore down my trans and VB there wasn't a spring under the plate with the 3/4 accumulator. What is the purpose of this? It has the alum 3/4 and plastic 1/2 .
And no I didn't mis place it lol
Moderator
The primary "ingredient" of the 1-2 and 3-4 accumulators is pressurized fluid between the separator plate and the piston. Similar to a shock absorber. The pressure of the accumulator fluid is set by the Accumulator Bushing/Valve spring in the valve body. (This is the spring in Step 4, Page 2 of the Transgo HD2 kit).
The accumulator springs "modify" the action of the accumulators. Putting spring(s) on the side of the piston away from the separator plate causes faster/firmer shifts.
For the 3-4 accumulator some 700R4 and early 4L60E models had the spring on the separator plate side of the piston; I think this would soften the shift. Later models and shift kits, e.g. the HD2, put the spring on the piston side away from the separator plate.
So, a missing spring would give you a relatively soft 3->4 shift. For a firmer shift assemble it by inserting the spring into the case, then the piston, then the separator plate, exactly as in the HD2 instructions.
When I bought the car 5 yrs ago the guy I bought it from said "I went threw a couple 4l60e's in a short period of time once and my trans builder told me that hard wot shifts into 4th is y I keep braking them and said that I need to stop letting it shift into 4th so hard"
Is there any truth to this? Could this be why there is no spring for happy medium between spring on case side vs plate side?
Thanks
Thanks
Nothing since I've owned it, I was quoting the guy I bought it from 5 yrs ago I don't remember what he said he kept braking but I want to say it was a snap ring for some reason .
But recently the torque converter came apart, while I was tearing down the trans to check things out for damage and debris I noticed that there was no spring with the accumulator under the plate.
So I was wondering y someone would leave it out?
Moderator
Accumulator springs do occasionally break; not uncommon in the 1-2 accumulator as there will be many WOT shifts and WOT maxes out line pressure which causes faster shifts.
WOT 3->4 shifts are uncommon as, depending upon rear ratio, it would be between 120 and 150mph.
However, some "hack" mechanics significantly increase line pressure at all times by excessively adjusting the set-screw on the Pressure Control Solenoid (PCS). While some people might like the resulting extra-firm shifts, it is very hard on the trans, u-joints and rest of the drivetrain.
The next time the valve body is off, I would put the 3-4 accumulator spring back in, but I wouldn't remove the valve body just to do that.
Ya it's off right now whole trans is tore down gonna call Dana today about rebuild kits, the converter was still under warranty so it's been sent off should have it back fri or mon I think
Order a kit from probuilt last nite, it aways nice to have guys like Dana (PBA) around for incite and just good ol' conversation. He's forgoten more about this stuff than most of us will ever know about it.
Thanks Dana, great talking to you
For the case side blow a little air where the check ball was with your hand over the accumulator. Some thing with the housing side blow a little air in it they pop right out like this
