Tci flex plate 399754
The 54 was for a 4L80E style or 350/400 style snout-the FW went on the crank, then the round spacer made up the .400 diff
The 54 FW had a small spacer attached so the FW aligned with the starter
It came with longer metric bolts, but some stroker cranks had American threads-I had to hunt down correct bolts for mine
Cant remember if the 53 is the same FW w/o the snout spacer and bolts, but as said I think its a dual pattern for smaller converters
You need to meas the snout height on your converter in relation to the pads
