T56 to 4L80E swap in my '85 500SEC Benz
I'm considering a trans swap on my Benz. The car currently has a LS1 / T56 swap and I'm hoping the 4L80E will fit in the tunnel. Does anyone know if the outside dimensions of the 4l80E are similar to the T56? I know the T56 is a tight fit in there now.
Oh, the engine, trans and PCM are from a '98 Camaro. I noticed the adapter harness that is available is only for 99-up. Will I need to upgrade PCM to newer version and is it a direct plug in?
TIA
TIA
