Transmission problems
Old 10-02-2015, 02:42 AM
SS_DYoung's Avatar
Default Transmission problems
When I step on the gas and try to punch it my car pulls back then shoots off after it passes 20 mph. Then if I keep holding the gas the car revs up at around 30-40 mph. Another thing is the transmission heats up a lot and makes the interior of the car super hot. Also when it heats up and I try turning a corner it feels like my wheels are grinding or making a weird noise
Old 10-02-2015, 08:59 AM
GMCSIERRA5.3's Avatar
What transmission do you have? Guessing 4l60?
Old 10-02-2015, 10:01 AM
SS_DYoung's Avatar
Yeah I believe so
Old 10-02-2015, 10:02 AM
SS_DYoung's Avatar
I forgot to add that it was recently rebuilt 6/17/2015
Old 10-02-2015, 12:22 PM
who did the build? sounds like the 3/4 clutches are burnt..check the fluid see what color it is..if nothing is wrong with the trans the fluid should be very red/pink..if it is a purple/black color suspect something inside is burnt
Old 10-02-2015, 12:51 PM
SS_DYoung's Avatar
Ill definitely check, last time I did check it was perfectly fine, I'm taking it up there today cause they said it's a sensor that's messed up but I'm not to sure about the vibrating of the rear end while I turn corner or step on the gas fast
Old 10-02-2015, 04:27 PM
any if not most sensor/electric problem will cause the transmission to take off in second or third gear..doesnt sound like a bad sensor to me..goodluck too you sir trans should be covered under warranty
Old 10-02-2015, 04:49 PM
SS_DYoung's Avatar
Thanks and yeah it's covered
Quick Reply: Transmission problems
