4L80e swap clearance
Yep the plug clearance issue was my only problem. I probably didnt even have to cut the ears off the trans to get it in there. Are you using the BMR conversion crossmember? It worked good for me. You might have to grind the bolt hole a little bigger wherer the trans mount goes through the crossmember though.
Yes sir. Bmr crossmember here too and also opened the hole. I tried installing the trans my self but it seems i would have to make room for the rear cooler fitting.
Also was a huge pain because i had installed poly motor mounts and it seems the engine doesnt tilt back as much. Car is on jack stands by the way.
