4l80e 1000hp build recommendations
Hey guys, building a 1995 4l80e that can handle up to 800-1000hp. Supporting a 370ci s484 turbo build. I recently dropped off the transmission at my builders house and he emailed me this build list---
300mm input shaft ($289)
t-400 alum pro mod sprag and drum complete ($785)
t-400 billet forward clutch hub ($75)
clutch hub thrust bearing ($14)
steel, 400/425/4l80e forward .060 thick ($102)
friction, 400 forward and direct ($103)
4l80e shift kit ($125)
"We would also need o/haul kit filter bushing kit band & electronics. Plus your converter. Probably about 2200 dollars"
I already have a Yank pro series 3400 converter FYI.
1. What are your thoughts on this build list?
2. Anything that should be added or removed?
3. Anything that looks a overpriced?
In my opinion....You don't need a Aluminum Direct Drum unless your spinning the engine past 7,200 RPM.
The Billet Input Shaft & Forward clutch hub are recommended at this level.
With the Forward & Direct frictions & steels....Sounds like he is going to use Alto Red's & Kolene Steels. NOT needed!!!, The Factory Hi-Energy frictions work great! The stock 5 count in the Forward drum is fine, You can run 6 frictions in the Direct drum if you want using thinner forward steels. Same for the Intermediate clutches...Hi-Energy! Stock "Cellulose" O/D & Overrun clutches also.
The shift kit I am going to assume is a Trans Go 4L80E HD2?
Pros...
Intermediate clutch snap ring.
Direct Clutch Piston return springs.
Drilling a "Line to Lube bypass"
Larger Boost Valve & Heavier PR spring, I prefer the Sonnax 4L80E-LB1 boost valve for the O-rings & better machining quality. But the TG boost valve works.
AFL/Solenoid Filter end plug.
Cons...
Layered separator plate to dual feed the direct clutches, If you were throwing a shift kit in a wreaking yard unit.....It's better than nothing!, But your having yours gone through.....Have the Direct internally Dual Feed! Less chance of a leak/cross leak.
The pressure relief valve, These can develop leaks....Dropping line pressure.
I ream the AFL valve bore & install a oversized AFL valve 100% on these units, They always show leakage when wet air testing/vacuum testing, This kit is cheap...http://www.transgo.com/products.php?...dcountview=Yes
Another Valve Body wear point is the TCC regulator valve bore, http://www.sonnax.com/parts/2025
As for parts pricing, Will not get into that, Your builder has to pay his overhead, Cover warranty, Payroll, etc, etc...
Pros...
Cons...
Pros...
Cons...
Pros...
Cons...
so drop the following items=
- aluminum drum
- steel clutches
and make sure these are installed=
+ stock hi-energy/cellulose clutches
+ HD2 shift kit
+ billet input shaft
+ forward clutch hub
+ "direct internal dual feed"
+ oversized AFL valve
+ TCC regulator valve bore
thanks again for taking your time to write that.
Thank you for your input man! Okay so to put it into simple terms because I'm not that knowledgable on transmission parts-
- aluminum drum
- steel clutches
+ HD2 shift kit
- aluminum drum
- steel clutches
+ HD2 shift kit
Yes I know it's very vague. I would rather you be very into detail so I can explain myself to him easier. Any questions or anything you would like me to ask him?
How many stock 34 element Sprags have you broken? (With holding burnout procedure mishaps).
Your part list looks good to me.
The other thing to consider is your vehicle is light. That's going to be much easier on parts. You could probably get away with a stock input shaft but I believe it's always better to overbuild than underbuild. I don't like breaking down.
My car weighs 3320 with its old setup. Probably around 3400 with new setup. I will definitely be getting the bigger input shaft. I agree too. I didn't think that the first two builds.........
If you are going turbo, a trans brake is the best thing in the world! You will have a tough time getting the car not to roll forward on the 2-step without a trans brake when trying to launch it.
I have never broke a stock sprag because I went directly to a 36 steel, and then a 36 aluminum after that.
A trans brake won't make any less of "Street" car, you don't even know you have it until you want to use it. The rossler brake you don't have to engage the brake to go in reverse, Jake's D3 and North Texas Converter requires the trans brake to be activated for reverse. I have a North Texas Converter trans brake, and we wired it up to a relay which allows the car to go into reverse without using a separate switch.
[/QUOTE]
Pros...
Cons...
Pros...
Cons...
The separator plate on the TransGo units is a nightmare. Avoid sandwich plates at all costs.
I will chime in and say your builder is giving you VERY good pricing on these parts OP. I'm actually quite impressed, so rest assured. Those 36 element aluminum drums are VERY expensive, many retailers list them at $1,000 and above.
