4l80e rebuild kit options
Looking to rebuild a stock 2003 4l80e and I have some ebay bucks to spend. So been searching ebay for the best kit. The tranny feels like it's slipping in third, so I assume that's the direct clutches ? It's for a stock truck with a 6.0. Nothing special.
http://www.ebay.com/itm/200841595363
http://www.ebay.com/itm/271585225323
http://www.ebay.com/itm/360815798846
Also, the different stage kits, does that mean anything special ? I noticed one listed as stage 4, and another stage 2.
https://www.700r4l60e.com/store/prod...&cat=14&page=1
Dana at pro built can help you out he has cheaper ones too. Ive heard red altos were junk but who knows cant go wrong with borg
Alto has a bad reputation mostly because the Red Eagles getting used in 4L60E/700R4 3-4 clutch, They should discontinue the Red Eagle 3-4 power pack altogether....Not likely to happen though.
I wouldn't worry much about Friction material...Other than High Energy frictions are recommended to be used in the Intermediate & Direct clutch packs. I think the "Brand" of the friction material is a overblown topic, I have used Raybestos, Borg Warner, & Alto for years with no issues if the CORRECT material is used for the application.
Worry more about Hydraulic integrity....
Internally dual feed the Direct clutches. If you need instructions, let me know.
Actuator Feed Limit valve bore wear is pretty common on 4L80E's. This fixes the issue http://www.transgo.com/products.php?...dcountview=Yes unfortunately it fixes 6 Valve bodies & I don't know of any other way to buy it...
Boost Valve & O-ringed Balance plug, http://www.sonnax.com/parts/1985-boost-valve-kit
AFL end plug, http://www.sonnax.com/parts/2031-afl...lug-o-ring-kit
TCC regulator kit, http://www.sonnax.com/parts/2025-tcc...ator-valve-kit
Drill a .050" "Lube to Line" Bypass in the Pump Cover, If you need instructions, let me know.
The following users liked this post:
JoshuaGrooms83 (07-31-2022)
