a4 overfilled?
a4 overfilled?
i just finished putting a built trans in my car with yank 3600,
converter had a quart of fluid in it
Trans i know was bone dry, lifting and moving it around there was no fluid
i added 8 quarts.....
first picture is when its cold "yes i know" but the next few pictures is when its warmed up and gears cycled through...
I'm assuming its over filled?
cold
engine on warmed up
engine on warmed up
cold
engine on warmed up
engine on warmed up
Ah sorry, yes it's an fbody. 4l60E.
I added the fluid yesterday let it sit over night. Checked it to just see what it looked like cold. Then let it sit till operating temp and checked it in park. Got the same readings..... :/
Last time I did this to my old 99 I added like 10 or so and it was good. I must be rusty after 5 years of not having an fbody.
The flat style trans dipsticks are crap.
You could easily be wicking fluid from the side of the fill tube causing that high reading. Tell tale sign would be very high fluid level on one side of the dipstick and much lower on the other side.
Take for example, 4l80 dipsticks, 91-96 has an S-shaped bend at the end that keeps the important portion of the dipstick off the wall. 97 up is flat. Also note, the much higher full level on 91-96. This is the correct level for performance applications (case to pan interface or 1/4" above). 97 up "full" level per GM leads to fluid starvation at hard acceleration and burned up 1-2 clutch pack.
Be very careful when determining trans fill level.
Originally Posted by bbond105
Yes, your shifter cable is broken.
