4l60e tail housing bushing inspection/specs????
Old 12-22-2015, 08:14 AM
ironmikektm525's Avatar
Default 4l60e tail housing bushing inspection/specs????
Putting my tail housing back on my trans. What do i look for o see if my tail housing bushing is worn/ok? Its perfectly smooth but does have some discoloring. Drive shaft/old seal didnt leak ect. Is there a spec so i can measure bushing. Are they know to wear? Has 132k on it. Im **** thats why im asking. Thx
Old 12-22-2015, 10:53 AM
built408's Avatar
If its questionable, just replace it. It cost a few bucks. Not worth measuring, inspecting, etc.
Old 12-22-2015, 01:40 PM
Ok thx. Special install tool is required right?
Old 12-22-2015, 07:39 PM
clinebarger's Avatar
Is this a LS1 F-body?, If so, The bushing is lined with Teflon & rarely wears out on a car. I replace bushings 100% on customers transmissions, Though on my Camaro, The bushing was in perfect shape & I reused it.
Old 12-23-2015, 07:06 PM
Yes ls1 fbody. Ok good to hear!!! Thx
Old 12-25-2015, 12:16 AM
joecar's Avatar
If the yoke wobbles significantly, or the yoke shows a wear pattern (the yoke is harder than the bushing), then replace the bushing (and the yoke if it is worn).
Drive it out using a bushing driver that doesn't bind (drive it into the housing); drive it in the same way (from the narrow end).
But as was said above, they're usually ok.
Old 01-03-2016, 04:13 PM
PBA
PBA's Avatar
Always use the Teflon bushing here. I have seen them go over 300K miles and still be in good shape. This never happens with the Bronze bushings. Always polish the driveshaft yoke with 600 - 1500 grit sand paper in the direction of rotation. The yoke must be in perfect shape, and always use the 3 lip Vamac rear seal. Some of these seals come with grease already in them.
Old 01-05-2016, 12:37 PM
joecar's Avatar
Where can I get such a seal (do you have a pic of it)...?
Old 01-05-2016, 12:57 PM
coryforsenate's Avatar
I believe this is the seal you want for the rear (Vamac 3 lip), confirm that it's the one you need before purchasing. It's pretty easy to install. One came with my rebuild kit.
http://www.makcotransmissionparts.com/74074.html
Old 01-05-2016, 01:06 PM
joecar's Avatar
Ok, thanks
( I'll confirm that it's a Vamac 3 lip for 4L60E extension housing )
Quick Reply: 4l60e tail housing bushing inspection/specs????
